Don't know if any of you guys have heard of toyodiy.com. It's got parts listings for pretty much all Toyotas. There's also a section for "tech write ups" which appears to just be links to other toyota tech stuff around the web. I've really only used the parts listing bit of the site.
Anyway, it's a really awesome resource for figuring out if parts are interchangeble between different years/models. Also means you can go to the dealer with part numbers of those odd parts that the dealer is unable/too useless to find themselves.
If anyone is unsure how to use it just post up here and I'll try to help out. I do spare parts for a living (not toyota...) so I have a good grasp of how the listings work, they can be confusing at times. I was going to write up a quick tutorial but I'm at work so I should probably be doing some work...
http://www.toyodiy.com
ToyoDIY.com
Re: ToyoDIY.com
haha that site says phils chaser is a 97 not a 98....
Re: ToyoDIY.com
That would make sense, arent 98 up all series 2? his is series 1 so 97 seems more correct?Unstable wrote:haha that site says phils chaser is a 97 not a 98....
Re: ToyoDIY.com
Manufactured in 97..98 when it was sold and registered so it still makes sensecorrupt wrote:That would make sense, arent 98 up all series 2? his is series 1 so 97 seems more correct?
Re: ToyoDIY.com
Yeah that sounds right. same with mine I think, it's production year is 96 but rego'd as a 97.Unstable wrote:haha that site says phils chaser is a 97 not a 98....
