Andrew's JZX110
Re: Andrew's JZX110
looks good bro, any plans to upgrade the turbo?
Re: Andrew's JZX110
like I always say andrew, i'm loving this car!
did it make any difference removing the J-Pipe?
i'm planning on doing the same thing with mine, what parts did you need to do the job?
Re: Andrew's JZX110
Nice , I'd also be interesting in knowing what you did with the J pipe removal .
Re: Andrew's JZX110
I was lucky with the J pipe removal as the HKS turbo can take both the factory 2 bolt flange and a 4" silicone joiner so i just got a 4" alloy 45deg bend and cut it to size, got a nipple welded on for the breather. The factory turbo and alot of the other bolt on turbos have a 2 bolt flange so you would have to get a flange made up then welded up to an intake pipe.
Havent noticed a huge difference doing it apart from slightly louder induction noise. Gotta be better running a direct intake tract though.
davealdworth, its running a hks gt2835 turbo
Re: Andrew's JZX110
Hey Andrew,
What blow off valve is that? Never seen it before.
Re: Andrew's JZX110
Its a Sard R2D2, Pretty loud!
Re: Andrew's JZX110
Andrew are u on instagram? Anyone out there on instagram?
Re: Andrew's JZX110
Where did u get your roof spoiler and lip spoiler?
Re: Andrew's JZX110
Roof wing was from jp and rear spoiler was from a guy that use to sell us carparts at work
Re: Andrew's JZX110
from seeing pics of your engine bay ive motivated myself to start on the j pipe removal on my 100. how did you mount all the little hanging lines and plugs which bolted to the jpipe?
