So who actually has high flowed there Ct15b and not just talked about it like me?
Results? Comments?
And go...
Ct15b highflow
Re: Ct15b highflow
Best give Steve Murch a PM.
Does this for a living.
https://www.facebook.com/pages/Steve-Mu ... 79?fref=ts
Re: Ct15b highflow
Yes well aware of this but I decided it might be a good idea to try and get a thread going on people who have actually done this so that other people can get some basic information without ringing up Steve
Trying to minimise the phone calls Steve gets so that he can spend more time building and supplying awesome turbos
Sound good?
Sound good?
Re: Ct15b highflow
Sounds good to me
Re: Ct15b highflow
As a bit of a base for those that don't already know here a little background on the ct51B http://www.turbochargerkits.com.au/tag/ct15b-turbo/
In other news there are people in the soarer community in Aus and the US using the CT15b's on the VVTI's and gaining around 250-280kw with some supporting mods in this thread
http://soarercentral.com/sc-forum/messa ... 28706.html
Likethey say in that some people have been using GT30 cores but that's old technology now. Be keen to see if anyone has used the core from a borg warner
Re: Ct15b highflow
logan you know my thoughts on the hi flow issue
in my mind ( and in my opinon here ) its the best bang for buck upgrade you can do
comparing the stats and figures etc the Tomei set is effectivly a glorified hi flow anyway you just pay a crap load more for it
as a matter of fact the high flows that steve does ( or has done for me ) has bigger exhaust and intake compressor wheels, unsure on shaft size tho
my set up is supposedly good for 450hp to 500hp so steve said all those years ago as it flows some sweet CFM
the best thing you could say to steve is exactly what you want to do with the car and where you would like the power to be and that is a fantastic starting point
i will dig out my inv from steve as it has some better info on there
Re: Ct15b highflow
Yeah deffinately know your thoughts jarred
Was actually reading some old posts where you said that AJ was doing a highflow and I think Dom and SimonmkII as well?
My current plan is to go through Murch and get my spare highflowed. Just trying to get some more information on past set ups he has done.
I understand he has been looking at fitting holset cores to them?
Re: Ct15b highflow
what did your highflow cost you I know a few aussie guys that would be keenFLAWLES wrote:logan you know my thoughts on the hi flow issue
Re: Ct15b highflow
sorry dude, sworn to secrecy
if you want an exact price its best to contact steve through facebook
he has done a few high flows for some ozzy chaps from what i can remember
rgds
jarred
rgds
jarred
Re: Ct15b highflow
unsure on the holset core, but he is a magician when it comes to retro fitting thingsch4sernz wrote:
cutting his way in and welding his way out
another good chap to talk to is Chris @ alltech he is also the mantis with all things turbo
( logan your work should use them for all your boch diesel equipment and garrett stuff so cheap )
