BRAND NEW PAINT Full Aero
Stereo - kenwood 25th anniversary 4 channel and 2 channel amp
12 inch kenwood sub in box. 6 1/2 inch components in front 6in 3way in rear door
kenwood single din head unit
Suspension - Greddy hypermax full tap 12 adjust damper.
solid bushings for subframe engine transmission and diff
rear sway bar
TRD diff with 3.9 final gear
Fuel system- Sard collector tank with 2 sard 280 pumps, 1 walboro 255lph feed pump. 2 6an in lines to fuel rail, 1- 8an return, 800cc side feed injectors,
Engine- Completely Rebuilt 2JZ-GTE , 272 cams, new springs and retainers, greddy intake manifold, 100mm throttle body, BRAND NEW 3 core greddy intercooler, 52 mm aluminum radiator. gt-4088r turbine, greddy wastegate. stainless exhaust manifold. 80mm full exhaust.
Trans - 6 Speed Getrag Tranny with ORC Triple plate clutch
Brakes- Supra Big Brake kit, all lines were redone and brakes are perfect.
Computer management - HKS V-Pro 3.1
CUSCO 21- 6 point cage
Everything on this car has been redone. I have not even had a chance to drive it yet.
Im selling due to the military reasons.
Im making this like an auction, She goes to the highest bidder.
Tear Down
Head cleaned and better than new
Completely Rebuilt
