FS: 2x CT15b Turbos - $200 Each!
Tofu
Post by Tofu »
both in working cond (130,000~km)
good for someone who wants a spare to highflow!
1x available now
1x available end of february
ta,
Phil
021647974
archon
Re: FS: 2x ct15b turbos - $200 each?
Post by archon »
I might be keen for one as a spare
You Tomei'ing?
Tofu
Post by Tofu »
Sure am mate! :D
I bought a spare turbo to highflow a while back however I bit the bullet and went with the M8280 instead so i'm now left with 2 spare ones once the Tomei goes on.
Where in NZ are you?
archon
Re: FS: 2x CT15b Turbos - $200 Each!
Post by archon »
Down in New Plymouth, you going to drop it off? Sweet!
Yeah the Tomei is hard to pass up, a brand new turbo, 100% bolt on and enough flow for 300rwkw (I have been knee deep in the threads on JZX100.com - as you probably have to), but I think a milder high flowed and steel wheeled ct15 might suit my needs better. Having said that I'll probably end up doing what you are... You doing the poncams too?
Tofu
Post by Tofu »
I should beable to work something out for you. Flick me a PM.
The high flow will be a better turbo for the street as it'll keep its response on normal boost conditions (10-14psi) whereas the tomei doesn't give any major gain without more boost fed into it (16-23psi). I've just completed a big order from overseas and couldn't resist the turbo while I was at it.
I'm doing Pon Cams as well. Should be a healthy increase of power with them too based on Tomei's R&D
A really good read here: http://www.tomeiusa.com/recentmail.asp?mid=587
As the Steve Murch high flow is a similar size (based on Jared's measurements) it should give a very similar power figure in comparison to the Tomei minus the cost and bling factor.
Tofu
Post by Tofu »
better late than never...
the other CT15B is available now if anyone needs one for a highflow or rebuild.
I've had no problems with it over the last 2 years. Still works fine.
Offers!
