1JZ to MX83 Crossmember Question.
Re: 1JZ to MX83 Crossmember Question.
yea but then you need a cert, anyone can make mounts up but having it factory mounted is the way to go if you dont want to cert
that is 100% Correct.
This one's for Jonno. I have a G series diff from an MA70. Would the diff case swap over to the MX (G312) housing?
I suoprt pulik ejukashun!
the centres swap NOT the housings
