Anyone know if these would suit a jzx100?
http://www.trademe.co.nz/motors/car-par ... 808745.htm
Manual parts
Re: Manual parts
bit pricey for some pedals, x member and a driveshaft. dont think they would suit x100 though
Re: Manual parts
i think you can use everything but the drive shaft as its either longer or shorter.... but i know the mounts are slightly at different heights
also pends if its from a jza70 or 80
Re: Manual parts
Neither.FLAWLES wrote:i think you can use everything but the drive shaft as its either longer or shorter.... but i know the mounts are slightly at different heights
Looking at that driveshaft, I'm picking GA61 Supra/Celica bits.
