Unknown outlet
Unknown outlet
I had the 110 up on the car hoist and I noticed some sort of outlet that looks like it may have leaked water at some stage due to the water like stain. Does anyone know if a hose is missing or something? This is looking up right next to the turbo downpipe.
Re: Unknown outlet
I will have a look tomorrow and compare it with mine.
Re: Unknown outlet
thanks bromurdoko wrote:I will have a look tomorrow and compare it with mine.
Re: Unknown outlet
Aside from not having a Kitty CAT, mine's the same. Nothing attached to the outlet thingy.
Re: Unknown outlet
hmmm, interesting, I was only concerned as it looked like it may have been leaking something at sometime or possibly an engine mod of some sort. All good, cheers for the infomurdoko wrote:Aside from not having a Kitty CAT, mine's the same. Nothing attached to the outlet thingy.
Re: Unknown outlet
Is that coming off the block? I think i noticed a random outlet like that on my 100 when i had the engine out.
Re: Unknown outlet
yeahSimonMkII wrote:Is that coming off the block? I think i noticed a random outlet like that on my 100 when i had the engine out.
Re: Unknown outlet
If it's got a water like stain then it's probly the drain for when you flush the block to get all the water out should have a 14 mm head somewhere there to
