i would rate mikes work above katsudai manifolds,
Im going to give him a ring today cofirm a few things.
Sinco customs discounts
Re: Sinco customs discounts
keen to cusomize headers for 1uz.. twin turbo sequential setup plus engine mounts .. whatevers needed for cert..
let me know manAlex wrote:i would rate mikes work above katsudai manifolds,
he can have my car to do the testing and fitting and or use the spare dump pipe i have
okay, i went and had a talk to mike today,
hes keen as to get this going.
im helping him setup an account now and will get him to post a thread once
his account is up and running.
mint sooner the better
Ill be keen for a dump pipe also
ok so how many are keen for dump pipes?
unstable?
flawless?
watda?
unstable?
flawless?
watda?
yup... im in
I'm keen. What flange design will be used at the bottom - factory or 3" etc?
factory 3"
just dropped off my spare dump pipe to mike to be copyied and made better
stand buy for update soon
