doing a manual conversion for a mates jzx81, need everything really, ive got the pedal and handbrake so need:
jz bellhbousing
w5* box (midrear or rear shift)
jz push type flywheel
bearing carrier
fork
master
slave
line
front driveshaft (manual ga70/gz20 will work)
i know its like asking for rocking horse shit but let me know if any1 has anything.
0273082550
kthx
WTB: w5* box and jz manual parts
Re: WTB: w5* box and jz manual parts
buy my mates jzz30 and strip it out
http://www.trademe.co.nz/motors/used-ca ... 517332.htm
may be the wrong drive shaft and what not but at least its all there
na he cant afford that, that'll go for over 5g easy
got bellhousing, flywheel and driveshaft so really just want a gearbox i can make the rest work
w55,57,58 someone must have 1 ?
Bosozoku_GX71
Haha when I blow up or crash my 71 you can have first dibs on the w57 hahaha
JZ = engine code
X = Chassis
71 = Series
therefore... jzx71
X = Chassis
71 = Series
therefore... jzx71
it wont blow up its a jz, u crash it u fix it, good way to learn panelbeating i learnt the hard way, never drink and drift
I have a rear shift w57 gearbox.
out of 2y corona done 150 ish kms.
Logan
Logan
you have a pm logan
replied
Logan
Logan
