ok my tensioner is getting abit shagged i think on the
water pump etc belt, because its abit more loose than it should be,
and it squeeks a bit.
What parts should i replace for this? just the tensioner? as the belt was replaced 10,000 ks ago ish
also how hard is this job? has anyone done it before?
1jz vvti in case you haven't seen my build
Water pump belt tensioner??
Re: Water pump belt tensioner??
inspect the belt dude, stuffed tensioner will tear shreds out of a belt
just look at the outer edges and you will soon see
but i personaly would do every thing
belt
tensioner
waterpump
fan belt
also fyi its cheaper ( or was ) to purchase the whole water pump and back housing as a unit rather than the water pump,
if you want this stuff let me know i will sort it alot cheaper than most
belt
tensioner
waterpump
fan belt
