WANTED: 1JZGE early water pump pulley + other shit
Rob
Post by Rob »
As per above.
And alternator 3 pin plug. Probably same as 1JZGE.
Mike
Re: WANTED: 1JZGTE early water pump pulley
Post by Mike »
from what car? Jzz30 is good, althoiugh id get a jzx90 version as the wiring and plugs are what you need.
XQZIT X90
Re: WANTED: 1JZGE early water pump pulley + other shit
Post by XQZIT X90 »
went through this with mine will see what i can hunt down you may have to un-bolt and convert the plug is yours the oval/rectangle plug or the round one?
S.A.S. Suspension and autoparts specialists for all your under-car needs call 09 444 1390 and ask for Lee
Bosozoku_GX71
Post by Bosozoku_GX71 »
try jonno2002, i bought heaps of shit off his 1j. its all pre vvti and shit
JZ = engine code
X = Chassis
71 = Series
therefore... jzx71
