HI all i have a 1jzge jzx90 cresta that i am going to be wreaking so will have parts available soon
i am taking the d/shaft and diff and probably the interior but all other parts will be up for grabs
also may end up taking the gearbox aswell
this model has the digital cluster but i dont want it lol
hit me up 0211845009
JXZ90 cresta (matt black) (f#$%ked bonnet and LH guard)
S.A.S. Suspension and autoparts specialists for all your under-car needs call 09 444 1390 and ask for Lee
speedracer_nz
Re: JXZ90 cresta (matt black) (f#$%ked bonnet and LH guard)
you wanna sell the a/c-heater controls in the middle? Can you post a pic of them?
yeah sweet as do you need the surround was hoping to use it as my 1 i\has a split will post photos asap
hi all have posesion of vehicle now ask and you shall recieve =)
-RH rear diff mount
-Diff(if you're not taking it)
-Washer bottle
-Gearbox X member
-Washer bottle
-Gearbox X member
there is not a RH diff mount as its non turbo and also im taking the diff where abouts are you?
You sure? 'cause my LX90 had two mounts. It's Rob here from Toyota.
And can I get the boot/fuel release unit?
yeah sweet as willl pull it ouut 2day for you ...
I would like the crossmember please.
Just give me a pm when you've got it further apart.
