Aristo is front sump, Supra is rear sump. So you'll need a turbo rear sump with oil pickup for your turbo motor to go into the Supra.twojayzeejza wrote:will i need to swap the sumps over or will the aristo sump fit the supra?
Or you can drill out the pre-marked template on the NA sump for the oil return, tap the two bolt holes and bolt on a oil return from turbo motor.
