Tofu - Phil's JZX100 Tourer-V
They are a universal PCB of White ultra bright LED's, they wire onto a generic bulb shaped fitting and go onto the factory terminals. I can source them however they are quite pricey, (about $40 each). Only problem is that LED's cannot dim so they are either on or off.
Tofu wrote:They are a universal PCB of White ultra bright LED's, they wire onto a generic bulb shaped fitting and go onto the factory terminals. I can source them however they are quite pricey, (about $40 each). Only problem is that LED's cannot dim so they are either on or off.
yea thats what i want, to be able to control my lights just in case, im looking for a green or red leds + relay....
i'll get back to you about it just need to do more research
it can be done quite easily, just set an override switch off one of your door switches and it'll turn all your interior lights on
You can get all sorts of LED replacement bulbs on trademe cheap as. I've had them in my car now for over a year, they dim up and down just fine.
lol diagrams?Tofu wrote:it can be done quite easily, just set an override switch off one of your door switches and it'll turn all your interior lights on
Nice mate, very nice!
looking boss Phil!
Nomnom
1995 Toyota Supra - Twin-turbo - 6-speed - Aerotop
No ABS. No Traction Control.
thats fuckn awesome! same color as mine too!
