Certed Wof/Rego
Full Truam Kit from Yahoo Japan
JDM Roof wing
Black DG Paint
Full Pre-Face lights
HID's (not fitted as wof issue)
Custom BC gold Coilover with 18/12kg Springs
JZX110 Castor arms Modded to suit
YAJ 25mm Roll centre correction
JZZ30 Turbo brakes (new brake lines)
SAITO spec Knuckles with extended rod ends
Rear camber and castor arms modded (0-1deg camber)
New Knuckle bushes
G-S Solid Diff Mounts
JZX100 tourerV Subframe
GT Motorsports Subframe lockers
Cusco type RS 2 way LSD
JZX100 V spec axles (10mm Allen Key Type)
Work Emotion CR kai 18x9.5 +20
Potenza 225/40, Nitto 225/40
90k JZX100 VVTI 1jz-gte
Genuine Toyota Waterpump/tensioner/cambelt
JZZ30 throttle Body with TC delete
Sard/denso 530cc injectors
Link g4+ storm with factory toyota harness
Braided PS lines
Full Stainless exhaust
3" Dump pipe with V band
Apexi Titanium Muffler
JZX100 R154 Remote shift
Rebuilt Uprated Exedy Hyper Single clutch/Fly
Greddy Front mount with custom alloy Piping
Steve Murch Modified CT15b with steel wheels etc
Modified Factory BOV
Full Interior (black/grey)
Tourer V dash
Tourer V woodgrain
Older style Nardi wheel with HKB boss
Bride Brix recliner
Bride sliding rail
Apexi Boost gauge
Dyno tuned by glen suckling to 215kw atw, a bigger turbo would send it close to 300kw
18k Firm please.
Call or txt me on 027 333 0125
