JZX110 Diff Swap
JZX110 Diff Swap
Anyone here done a diff swap in their JZX110. From an open to a torsen?
Re: JZX110 Diff Swap
What do you need to know regarding this?? There is a heap of info about this on JZXworld.com
Just need to know if you can just straight swap them without needing any new parts.
You will need the whole torsen diff, including the casing, not just the centre. I did it on my JZX110 with the whole casing and it was a perfect fit. Hope that helpsfreshez wrote:Just need to know if you can just straight swap them without needing any new parts.
Plus, is yours an IR-V? I'm assuming it is.
I have the whole diff incl. casing. Just what I wanted to hear
I'm sure I read somewhere that you needed new "axles" or "side gears" when swapping the open for a torsen as one diff was thinner than the other.
and yes, it's an IR-V
Nope you don't need anything apart from the whole diff. That could have been me referring to a hilux diff centre that I bought to fit into my 110. Didn't fit cause it was slightly narrower.freshez wrote:I have the whole diff incl. casing. Just what I wanted to hearI'm sure I read somewhere that you needed new "axles" or "side gears" when swapping the open for a torsen as one diff was thinner than the other.
Is this Tristran's old 110? If so, I thought he had already fitted a torsen that he imported from Japan through Ewan @ stacked
Yes its a straight swap. yes, that WAS my 110... no I haven't fitted it as it didn't arrive until the week it was sold.
Make a members ride thread man. Such an awesome car!freshez wrote:What Tristian said ^
