As per title.everything needed to convert your cressida to a manual.
Comes with,
W58 (not a w55) Alloy split-case box with rear most shifter and lever with boots and mount.
SX80 Clutch box with master cylinder.
7M-GE/GTE Bellhousing.
Clutch/pressure Disc & Flywheel with bolts,
Slave Cylinder/Fork and throwout/release bearing.
Driveshaft.
G302 LSD diff.
http://www.trademe.co.nz/Browse/Listing ... =654581440
Toyota Cressida W58 Manual conversion.
I suoprt pulik ejukashun!
Re: Toyota Cressida W58 Manual conversion.
Don't you think this is slightly overpriced? It's almost the same price as a Japspares JZX R154 conversion. Which would be better.
u could buy a brand new r154 for that price too....
I believe you're overlooking the finer details of the conversion. I also am of the opinion that you've not read the description/title carefully. Theres currently no r series boxes (on trademe) with a 7m bellhousing, not to mention the r154 doesn't fit the stock cressida tunnel (without hammerwork). Clutch setup is different, remote housing sits too far if used, drive shaft length varies, slip yoke, collar, speed sensor for series one. My setup is bolt on with the only mod/extra being the brake pedal. Everything else is bolt on.
I don't think its too expensive. Japspares sell their R154's for like $3500 without an LSD. This has an LSD along with all the pedals. And with brand new R154 boxes, they don't come with anything other than the box itself.
I'm with this being a fair price. I'd happily pay an extra $2-300 just so i don't have to hunt for the gay shit.. I believe my time is worth more than that..
chaseher080
Would you at all drop minus a few not needed item likee 7m housingvmaybe few other bits. I have a w55 gbox and am wanting to go w58 but if everything bolts up to what I already have id only need gbox and diff right? Sorry still noob with the toyotas I come from being an s chassis lover
chaseher080
1991 jzx81 mark 2 grande. 1jzgte single turbo yada yada ya got it in rough condition am trying to restore but having trouble with some parts like gbox and panels and aftermarket seat rails ect
Is yours the gun grey one. I believe you were looking for the speaker cover visor and other stuff?
