selling the engine out of my Toyota Supra JZA80 1996
-well serviced by toyota for past 5 years, have paper work somewhere for it
-engine has done about 114,000km last service was at about 107000kms and the oil is still golden
-can be seen running as will remain in car until sold
no smoke etc very good condition engine only selling as putting a turbo motor in soon
on trademe also
http://www.trademe.co.nz/a.aspx?id=370015845
edit- is manual and will come with ecu but no loom or flywheel
FS toyota supra 2jzge complete motor
- twojayzeejza
speedracer_nz
Re: FS toyota supra 2jzge complete motor
vvti? Why don't you go na-t? how much power you wanna make?
- twojayzeejza
non vvti, na i want to be able to run more than 10psi
Na engines have higher compression therefore putting big turbos will blow it up.. you'll need to change the internals with a gte internals e.g. conronds etcc (i think) for it to work as you planned and probably a thicker gasket to lower the compression.. plus the layout of a 2jzge is lets just say.. not very good looking haha
- twojayzeejza
the size of the turbo wont change if it blows up, its the amount of boost/detonation that the standard cast pistons can take, the rods are the same from memory the only diff is oil squirters and comp ratio, if you were to turbo the NA i wouldnt bother running more headgaskits to lower compression because that also causes more stress on the HG so a higher chance of blowing HG
speedracer_nz
damn there is still
ALOT
of mis-info around bout these engines (GE,GTE). People don't give the GE credit for what it can do/power they can make. There are alot of differences with these motors people don't know about other then the pistons and oil squirters but they are easy to overcome. My 2 cents anyways. GE+T for life
- twojayzeejza
no not mis-info i looked into doing +turbo and yes they can be good results but too much hassle to make it as reliable as a gte engine, iv had enough of having to make shit work, my previous car was one of the 1st turbo 4ages around and what a nightmere it was = 3 engines and $15000 and thats mostly parts cost as i did most of the work myselfspeedracer_nz wrote:damn there is stillALOT
speedracer_nz
Each to there own I suppose and depends what "hassle" means to you. You should never have to make shit work, there is always the right way to do something but it cost lots of money however
Can't really comment on the 4age other then thats alot of money to find the right way for sure
speedracer_nz
anywho i will leave your for sale thread alone now lol my bad
