Hey,
My 1JZ is running high boost and i dont know why, it doesnt have a boost tap or anything but it does have a mines ecu. Anyway its running about 20psi - 25psi on the standard twin turbo setup which doesnt seem right.
Any ideas were to locate the problem if there is a problem or is this normal for 1JZ to run which surely it cant be.
Thanks
My 1JZ is running high boost, HELP!!
arctiic.23
Re: My 1JZ is running high boost, HELP!!
How reliable is your boost gauge?
1JZ boost control is all mechanical, so if it really is running that much boost it'll be either:
Split/cracked or missing wastegate line
Broken wastegate actuator
Seized wastegate
Seized wastegate
