GX81 Mark II
GX81 Mark II
How to replace GX81 Mark II rear suspension
Re: GX81 Mark II
wanna be a bit more specific ?
Re: GX81 Mark II
yeah man, i want to know how to to replace the suspeion on a gx81? and if possible, do you know where i can get factory shocks for it?
Re: GX81 Mark II
you do realise suspension is more than just shocks and springs, theres arms and swaybar etc.
i dont have springs they sell to quickly, if you want shocks get new ones.. 2nd hand shocks are a waste of time.
im assuming your wanting to know how to remove the rear shocks.... 19mm nut and bolt at the bottom and 3 12mm or 14mm nuts (cant remember) at the top but you have to remove the back seat to get to them, all easy stuff tho
as for fronts, 3 14mm nuts at the top, remove the swaybar link from the strut, cut a piece out of the brake line bracket (if it hasnt already been done before) so u can remove the hose without spilling fluid, take the brake calipers and rotors off, two 17mm bolts going up from the bottom to remove the strut from the knuckle, think thats the lot from memory, all simple
