anyone have a Manual GA70 Supra Drive shaft. I was told a Manual GA70 Supra Drive shaft will fit in my GX81 with the W55 in. Also if anyone has a Manual GA70 X member, id like to possibly buy both.
txt on 0211367662.
Drive shaft
- Hachi-ichi
Drive shaft
E-GX81-AEPQF. 8E3, FB81
Re: Drive shaft
no the supra gearbox xmembers are different, you need a x7,x8 manual crossmember possibly x6 but havent tried that yet.
Re: Drive shaft
X6 gearbox crossmembers are different to X7
I have a auto X7 crossmember you may be able to modify to fit
- Hachi-ichi
Re: Drive shaft
right, so I need Manual GA70 Drive shaft and either Manual GX71 or GX81 X member?
Re: Drive shaft
yes or drill some holes in your auto xmember and it will fit
- Hachi-ichi
Re: Drive shaft
ok chur, I will be able to redrill my X member so thats cool.
Re: Drive shaft
yes i said that in your other thread if you had read it
- Hachi-ichi
Re: Drive shaft
got my GA70 drive shaft with a good condition yoke also which is nice. Now just nee to swap the cradle bearing mount with my auto one and im good.
