Big Brake Kit for JZX100
Anyone have this for sale? Im looking to upgrade from the stock setup.
Re: Big Brake Kit for JZX100
Could you modify the jza80 big brakes to fit. There a set on tradme
Yes, you can modify them. how much is the set on trademe??
1200 for the front and 1300 for the rear
Holy shit, thats expensive. Thanks man, but I think I'll keep looking. I can't afford that!
Wow, wouldnt willwoods be cheaper than that?
Yer there not cheap. But first full set I've seen on tm for years.
i can do brand new calipers ( jza80 4 pots ) for NZD $650 for the pair ( new ), you would have to get the adapter nuts from nite parts in japan and the 328mm disc's from your local dealer over there
That's a good price. Don't get much cheaper then that
Hey mate do you have the niteparts web address? I might get some adaptors and those calipers if you can still get them?
Cheap wastegates cost motors
