Apexi Safc 2 Fuel controller, suit 1j and 2j
Mike
Post by Mike »
Can make really good gains on your jz's with these! also they raise the factory boost cut!
http://www.trademe.co.nz/Browse/Listing ... =457638399
Re: Apexi Safc 2 Fuel controller, suit 1j and 2j
FYI bro, it's a SAFC1,
how does it raise the boost cut? does it have a defender built in?
Post by shweatypox »
Will this work with the VVTI 1J's?
Mike
Post by Mike »
Will raise the cut when you decrease Map airflow signal
