I have a 1998 Toyota Hiace Supercustom with the 1kz turbo diesel engine.
I have owned for almost a year but however now the mrs is driving it and she dont like it so she wants it gone and i will only settle for what I want.
In the last year I have fluently serviced it in all areas.
New front pads and Rotors. $600
New Top arms and ball joints. $800
Advanti 18"x8.5" rims, have 50mm lip. only light kerbing rash but chrome is flaking $600
New Kingforest 235/40r18 tyres 6000kms old $880
New Sway bar link bushes in rear. $150
Radiators removed and cleaned $550
Cobra Super Low Heavy Duty springs $250
HID aftermarket kit and LED side lights. $ 175
Fusion 6x9 in rear $100
fusin 4" in front $60
Sony headunit with aux input $ 200
sony 800w amp driving two 10" Pioneer subwoofers $400
Cambelt and tensioners, cam seal $ 480
Turbo Drain Pipe Replacement $280
and is in the process of repainting the front of van due to excessive stone chips. $450
it comfy, has good power, handles brilliantly and is stupidly cheap on gas
A tank gets me from tauranga to north shore, a bit of town driving and back to tauranga with a little over empty left. costs approximatly $95 to fill up.
Body has done 455000 but motor is 200000ks ish old as it had a motor change 75000kms ago due to old motor cracking head. Gearbox was also recond at the same time. all of which i dont have receipts for. But it the box and motor are tight and clean and use no oil or water. Motor has no "diesel smoke"
Will swap for jzx90 turbo auto or non turbo manual. or Jzx100 non turbo auto.
It is factory light green top and dark green bottom. It is a facelift model, not many around. Has never been raped for towing with no towbar ever fitted.
Msg me if you have a offer
Chaser to swap for 1998 Toyota Super Custom
