anyone ever done it before....
i can't seem to get at one of the bolts because its stuck behind the boot release/fuel flap release panel. Anyone know any tricks on trying to get some give out of the boot release/fuel flap panel as even when i undo the screws it doesnt have much give in it.
Any tips would be appreciated
jzx100 driver's seat removal???
Re: jzx100 driver's seat removal???
Undo phillips screw holding plastic cover that doubles as fuel/boot release levers, then pull this unit towards the front of the car. Should be enough slack in the release cables to allow a good 5-10cm of movement, thereby allowing you to get to the seat bolt.
sweet as bro thanks....bring on the recaros
