altezza into jzx90 - suspension
speedracer_nz
Does anyone know for a fact if altezza shocks and springs will bolt into a jzx90?
Re: altezza into jzx90 - suspension
they wont. does that answer your question?
speedracer_nz
lol yes it does
slipperywhenwet
Sorry to revive old post but I put toms adjustables into my old gx90. Fronts bolt straight in. Rears I got a large washer 2mm thick and welded it bottem side of the standard top hats and a welded lip on the washer for the inside of the plastic seat that holds the spring centre and had to drill the centre of the standard top hat out to fit the shock shaft. Bolted right up... even got a cert. I'm guessing standard suspension would be the same or easier depending on size of springs really. Hope it helps haha
Oh by the way they were out of an altezza
so the front does but rear doesn't?
sweet. nice to know.
so my 100 should fit altezza front coilovers... theoretically.
speedracer_nz
lol alex why bother answering my post if you obviously didn't have a clue to begin with?
that was what i had heard from others, and they seemed certain.
it think it was because only half fit they said the sets dont work.
i learnt something new.
no need to be a douche about it.
speedracer_nz
