This a JZ series turbo oil drain fitting it will fit the 1JZ/2JZ upper oil pan. You will need this fitting to mount on the upper oil pan to accept a -10 AN drain line off of your turbo when you do that single upgrade. This item fits perfectly and is VERY low profile to give your AN plumbing as much room as it needs close to the crossmember on a 1J. Look at the detailed photos.
Its $52 Shipped anywhere in NZ!
