http://www.trademe.co.nz/motors/car-par ... 850575.htm
Hey guys does anyone know if these will work if I am using cut and shortened shocks and coil over sleeves?
Camber plates
Camber plates
JZ = engine code
X = Chassis
71 = Series
therefore... jzx71
X = Chassis
71 = Series
therefore... jzx71
Re: Camber plates
dude do i have to tell u again! http://www.trademe.co.nz/motors/car-par ... 305976.htm
Re: Camber plates
I just can't justify it bro! The car is worth like what 4500 maybe. So I can't spend 1600 bucks on suspension! I would get second hand but they are hard to find. It's just a street car! It doesn't need full adjustable suspension! If I had a decent turbo street car then yeah sure.
JZ = engine code
X = Chassis
71 = Series
therefore... jzx71
X = Chassis
71 = Series
therefore... jzx71
Re: Camber plates
Only telling you because i've been down that track bro, your call
Re: Camber plates
Any camber plates will work provided the ID of the centre bearing is the same as the diameter of the shaft at the top of your inserts. you can someimes sleeve the shaft though or machine it down to suit.
You could probably just use the factory tops if you arent worried about shit alignment.
-GX61 1GEU-
Re: Camber plates
ok il think about it. i guess im still guna spend like 500 getting new shocks and all that shit. I might aswell start saving then.
JZ = engine code
X = Chassis
71 = Series
therefore... jzx71
X = Chassis
71 = Series
therefore... jzx71
Re: Camber plates
I am not sure about that but i wan to tell you Any camber plates will work provided the ID of the centre in bearing is the same as the diameter of the shaft at the top of the your inserts. you can sometimes sleeve the shaft though or machine it down to suit.
Re: Camber plates
Dwight what do you think about copying and pasting on computers do you think its useful?Dwight wrote:I am not sure about that but i wan to tell you Any camber plates will work provided the ID of the centre in bearing is the same as the diameter of the shaft at the top of the your inserts. you can sometimes sleeve the shaft though or machine it down to suit.
