FS: 1UZFE, 1GGTE, and Harrier/RX330 18" 5x114.3 set.
Rob
Post by Rob »
1UZFE: Cheap running 1UZ removed from crashed UCF11 Celsior. Engine will come will AFM, loom, ECU. No exhaust manifolds, hyd. pump or flexiplate.
1GGTE: in reliable, regular, daily driving use. Pulled from one of the tidiest GA70 Supras I've seen! Engine can be test driven and inspection is welcome! Comes with loom, ECU, AFM, ignitor pack, 1GE flywheel, clutch and cover plate. 1G-W55 bellhousing at small extra cost. Mounts to fit GX90. Front sumped fitted from 1GFE with sump baffles(so no oil starvation issues). Pretty much a complete conversion kit.
WHEELS: 18x7 +35 Offset Toyota Harrier/Lexus RX330 rims(Set of 4) with near new 235/40/18 Yokohama S-drive tyres. One tyre has a leak but still with good tread.
http://www.trademe.co.nz/Members/Listin ... ber=715461
