Basically my car has been burning oil for a while, it's now using about 1-2 liters per tank of fuel!
I'm hoping to get a complete 1JZ and drop it straight in.
Reply here or drop me an email if you have anything or know anyone that does
Thats what was causing mine to smoke. A $5 can of brakeclean fixed it allarchon wrote:What engine is in there now? What breather set up are you using? On a turbo engine with a failing PCV valve it will be pressurising the crank case and blowing oil out wherever it can.
Shit I didn't even realise that was a valve in there, I thought it was just a piece of tube to connect the hose to. We are talking about the little metal tube that sticks out of the rh (drivers) side rocker cover?Tofu wrote: Thats what was causing mine to smoke. A $5 can of brakeclean fixed it all
the PCV is located on the right hand side of the rocker cover. It should pull out quite easily and they tend to block up over time. When clean, the ball bearing inside and spring should move freely
It should be on the passenger side (right hand side when looking from front) and plugs straight into the cam cover. The rubber bung gets very brittle though so be careful it doesn't break and fall inside when you pull the valve out (it happened to me and it sucks big time having to pull the cover off to get bits out).SimonMkII wrote: Shit I didn't even realise that was a valve in there, I thought it was just a piece of tube to connect the hose to. We are talking about the little metal tube that sticks out of the rh (drivers) side rocker cover?
