hi there am just seeing if anyone would be interested in buying my soarer. started life as a green automatic 1uzfe since then has had the following
-rego on hold..just got a wof
-boot shaved and primed
-have brought a vertex bodykit but only have the rear bar on at the moment
-custom 3' exhaust from standard headers.
-factory manual interior gearstick trim and clutch pedal
-no rear seats in at the moment.
-remote shift r154 that came out of a cresta that had done 90 000 kms.
-niteparts bellhousing and billet flywheel.
-custom release bearing carrier
-exedy 5 puk clutch
-scarles alloy radiator with electric fans
-aircon and hydraulic fan removed(still have heater unit in car though)
-pod filter with home made cold airbox..works well!
-new power steering pump from late model 1uz.
-rolling on standard gtst wheels with allright tread
-clear project x side indicators
to finish it would need
- painted as it looks funny with white bodykit on green car with primer bits!
-lowering as they sit really high standard
-cover over hole in tunnel where the remote shift comes through
-could probably do with a new driveshaft as i made the one in it and havent had it balanced
-some sort of torsen diff or lsd
-better wheels
Am thinking it must be worth about 6k?maybe not...has been a slow project for a while..can put pics up if required or can pxt if interested.
0210506196
fs- 91 toyota soarer ...1uz.. r154 remote..5 puk
