List of things I'm going to sell... going to be taking photos and listing on tardme in the next few days, but if anybody here wants it express an interest before hand and you can take it off me.
17x9 Advan Super Advans, full set of 4, straight and true, with good condition 235/45/17's on them +40 offset.
235/45/17 Bridgestone Potenza tyres. 1-2mm tread on them, some with corner wear, ex police car tyres, have about 20 of them, buy as many as you want.
2JZ-GE complete upper assembly. Will be selling off in individual parts unless someone wants the lot, but includes full 2JZ-GE head with cams, rocker covers, distributor and leads, intake plenum and runners, throttle body, exhaust manifolds etc etc.
Spacers - Pair of 25mm hubcentric bolt ons with 1.25mm thread pitch, set of 4 20mm non hubcentric bolt ons with 1.5mm thread pitch
JZX90/JZX100 A02A open diff head, this is the bigger size 8" head and comes with stub axles.
Driveshafts - Have a couple of A70 supra automatic driveshafts, also a JZA80 manual W58 driveshaft.
1G-GTE manual bellhousings - 2 of these
A70 manual pedalbox - Suitable for GA70/MA70/JZA70/GZ20/MZ20
1JZ-GTE ECUs - one from JZX100 and one from JZZ30 I believe.
Stich 17x8 deep dish (sic) wheels - Pair only, one kerb smashed beyond repair to outer lip, centre and inner barrel fine. +35 offset I think.
2JZ-GTE clutch - Pull type clutch from JZA80 V160 box, complete with pressure plate, friction plate, and actuation gear (clutch fork, pull bearing etc).
If you want something, PM me a reasonable offer and chances are you can take it away before it goes to the masses on tardme.
I'm in Papakura, Auckland but happy to ship most items (except large ones like 2JZ head, or driveshafts etc) around the country at buyers expense.
Schtuffs for sa-leh (Car shitz)
Re: Schtuffs for sa-leh (Car shitz)
Hey man, im keen for the spacers.. how much are they?>
Hey man dont suppose you have a diff housing 4.1 ratio? ive blown my pinion wheel to pieces but have everthing else, just need the pinion or an open diff etc?
Cheap wastegates cost motors
Sorry mate, just sold my spare open diff head and I don't have a crown wheel or pinion.
Umm... things I've still got...
1G-GTE manual conversion - Pedalbox, bellhousing, flywheel, brand new clutch, clutch master cylinder, hardline and slave
1JZ-GTE ECUs - one from JZX90 and one from JZZ30
20mm hubcentric bolt on spacers - 1.5mm thread pitch for Toyota/Mazda/Mitsi
Engine mounts - both alloy brackets and alloy mounts from JZA80 to suit any JZ motor
Side skirts for JZX90/100 - One set of Traum, one set of Vertex and one set of unknown (Uras/BN style)
JZX90 facelift Mark2 tail lights
JZX90 pre facelift Mark 2 centre garnish and drivers side tail light
Misc wheel centre caps
2JZ-GE power steering pump with reservoir
JZZ30 stock intercooler piping
JZX90/JZX100 rear subframe with mounts
235/40/18" Tyres - Not great condition, but take all 3 for $50
Will list other stuff as I come across/think of it![Smile :)](./images/smilies/icon_e_smile.gif)
Hey how much for the 20mm spacers, I'm after a pair. Do they have nuts with them?
How much for the FL tail lights and rear subframe? cheers
archon: 20mm spacers I'm after $100, they have full set of low profile nuts, were new when we bought them (Cost over $160 from Driven) and went on a car thats done less than 1000km in the last year :\
Powder: $200 for the tail lights and you can have the subframe![Smile :)](./images/smilies/icon_e_smile.gif)
Are the spacers hubcentric? To suit a jzx90?
I'm keen if archon decides he doesn't want them.
They are hubcentric. 5x114.3mm PCD, 1.5thread pitch, 67.1mm hub bore, 20mm thickness. Have "Freeca" written on them, whether thats brand or not *shrug*.
They were on our Supra, but I could have equally used them on the JZX. The only thing is the hub bore at 67.1mm is to suit most aftermarket wheels, so you'll want hub locator rings to go under the spacer and properly locate on your hub (although I've never done this and never had a problem). Hub locator rings are usually a few bucks from a mag shop.
Oh and they're a goldy/bronze colour... just for spiffyness![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
