realistically for the JZX boys i will accept offers around $13,500. I really want this car to go to a good home.
will sell cheaper on factory 16" Tourer V wheels
body has done 240,000kms
-1JZGTE vvti swapped from a jzx100 (done 117,000kms)
-R154 manual gearbox (swapped from the same jzx100)
-swap is certified and was done by Keg at DKM Fabications to the highest standard
-HSD coilovers 14kg and 10kg spring rates (front and rear respectively)
-Cusco upper front arms with camber adjustment
-Hardrace adjustable lower rear arms
-KTS sway bars front and rear
-Blitz front mount intercooler
-Redline alloy radiator
-HKS stainless steel turbo back exhaust
-JIC Magic front strut tower brace
-Omori boost gauge
-jzx100 front lip, skirts and rear lip (these could do with some TLC to get them fitting perfectly)
-Advanti tech-x 18x9j +15 wheels with Achilles ATR Sport-2 tyres(4000kms old)
-JVC bluetooth headunit with x4 6" Clarion speakers in the doors(Kenwood amplified), x2 JBL 6x9s in the parcel tray (also Kenwood amplified) and a sony 12" sub in the boot (amplified as well!) The sounds in this car are killer.
-AVS 5 star alarm with triple imobiliser
the down sides:
-body could do with some love (some scratches, little dings etc.) side skirts need a bit of work to get fitting properly.
-front passenger side 'rape lock' doesnt lock at 30kph
-open diff B04A (8" diff)
-standard clutch (if you want to do big skids i would recommend a HD item)
WOF, Regd and certified.
This car is my baby and has always been run on factory boost (12psi) and
BP 98 octane and has been serviced with the best Penrite oils.
I also have a brand new Toyota Supra Big brake kit with 323mm rotors and SP500 pads etc. ready to go on the car for the right price.
email, txt or call if you'd like to arrange a viewing. 021 02430914
