Jzx90 Chaser
1jzgte with single turbo conversion, Ht18 turbo with bigger front housing and comp wheel, rb25 exhaust housing.
Engine was rebuilt to factory spec and has had maybe 10 track days, uses no oil or water and never overheats, runs perfectly
W58 remote shift gearbox but in process of 350z 6sp conversion which will be sold with car
Link G4 Ecu tuned to 280kw, has 2jz injectors and bigger fuel pump with surge tank and Turbosmart FPR so with bigger turbo will produce alot more power if thats what your after
Alloy radiator and powersteering cooler setup
Bc suspension in great condition still, all rear adjustable arms, front castor arms, RCA's and modified knuckles
Cusco front and rear sway bars, lock diff 4:1
Rear twin 2pot calliper setup with Hydraulic handbrake
18x9 Wheels
Racepro seats
6 point homologated rollcage, lots of extra bars added
Jzx100 BN sports style bodykit modified to suit , now with Traum front bumper
Custom made fiberglass rear doors and bootlid
Fiberglass front guards with moulds
Rear quarters are still steel but i have made moulds to make fiberglass ones if damaged
Vented bonnet
Great track car or D1 car
Did have rego but it lapsed after being on hold for 5years
Plenty more info but please call if interested
021689559
18k if you think thats too much please keep that to yourself, the market will ultimately determine the value
