Hey guys,
Has anyone tried changing rear axle for jzx90/jzx100 before?
Well, the CV boot on one side has ripped and I want to get the rear axle out but its stuck!
Tried hammer and even the hydraulic axle removal thingy as well.
Can anyone help?
Thanks in advance
Jun
Changing rear axle jzx90/100
http://www.NBUSnz.co.nz <- The Best tints.
Re: Changing rear axle jzx90/100
Could you be a bit more precise? Whats stuck? Outer CV splines stuck in hub which is the usual abortion one goes through come cv joint time.
luc3unitJZX
Wheel off. Take axle nut off, Then the 6 inner axle bolts to diff. Pull it toward wheel, it will drop down then the outer should pull out of hub
