1jz gte vvti wasted spark factory coils.
Have upgraded to new external coils and leads. All work fine
$300 for all 3
1jz-gte VVTI coils
Re: 1jz-gte VVTI coils
Is there a point/advantage to a wasted spark setup?
luc3unitJZX
compared too?? dizzy over wasted spark, or 6 coil over wasted spark?? Wasted spark uses less components. These are the factory 1jz-gte vvti coils. Ive Just moved to stronger spark coils which arent on plug type. Still wasted spark, just more spark and bigger leads.
just in general
All I could make out is less components, wasn't sure if there was a performance advantage
