2000 Nissan Silvia S15 200SX Spec R
Humina
Post by Humina »
Hi guys first post here and im looking at going into toyota power now :twisted: anyway heres my S15 for sale
2000 Nissan Silvia 200SX Spec R S15 SR20DET
Makes 209RWKW at 14 Psi boost
Garrett T28 Ball bearing turbo
Apexi Power FC + commander
Apexi airfilter
Nissan Z32 80mm afm
SR20DE 60mm throttle body
GK Tech Rocker Arm Stoppers
HKS Style Bov
Spitfire Coil Packs
Custom Alloy Intake Pipe.
Greddy Intercooler + Piping Kit
Engine Dampner
JDM Dump Pipe
Apexi Front Pipe
De-Cat Pipe
3.5" Apexi Stainless Steel exhaust
Greddy Profec B Boost Controller ( Set at 14psi)
Walbro Fuel Pump
Serviced 1/11/12 with Nismo Oil Filter and Castrol Edge 5W-30 When motor was out.
Also got new
- Genuine Nissan Water Pump
- Genuine Factory Thermostat
- Genuine Front + Rear Crank Seals
5 Speed S14 Turbo Box
Exedy Heavy Duty Clutch
C'Z Short Shifter
Tein HE Drift Adjustable Suspension with front camber plates
After Market Front Castor Arms
Nismo Front Strut Brace
Cusco rear Strut Brace
Subframe Lock Collars
Nismo 2-Way LSD
Front Slotted & Dimpled Disc Rotors
Endless CC-R Front Pads
17 x 9 Work Meister copies
Brand new rear 215/45/17 Neutons
5MM on front 215 45 17 Neutons
Factory front bumper + Bonnet
94 Honda Accord Front Lip.
Vertex Side Skirts
Ganador Style Mirrors
Laufen Rear Duck type Spoiler
350MM Momo Steering wheel
JDM After Market Boss Kit with airbag deletion Sensor
Buddy Club Bucket seat on Buddy Club Super Low Rails
Defi BF gauges. Boost,Oil Pressure,Oil Tempature,Fuel Pressure.
Blitz Turbo Timer
Drift handbrake knob
Will swap for JZX100 or 18K
027 529 0060
Thanks guys
