Will a G295 4.1 JZX81 MARK II LSD fit into a GX81 MARK II sedan with factory G252?
if not, then anyone know what ill need etc new half shafts...
Thanks in reply
G295 X81
Re: G295 X81
yes it will fit, even a70 supra diff centres swap over ive done it, also pull the lsd apart and check that the clutches are in order cause quite a lot of them have been rearranged so they arent so agressive, my one was rubbish till i rearranged the clutches now its ruthless as !
