im matt (escortman elsewhere) JZA80 supra
Re: im matt (escortman elsewhere) JZA80 supra
^^^what the hell is that?
murdoko wrote:^^^what the hell is that?
obviously an engine which is mounted with trampoline springs
Ford escort?
ford crossflow maybe a 1300 or 1600?
Logan
Logan
- twojayzeejza
ding ding its 1600 crossflow
with a top mount owtwojayzeejza wrote:ding ding its 1600 crossflow
and free flowing in mean free floating pipes
Good old dad and his ability to recognise old crap haha
Logan
Logan
- twojayzeejza
Going in the hole
Shot at 2011-07-09
Shot at 2011-07-09
Shot at 2011-07-09
also bought a 550x230x65 intercooler fills the hole quite nicly without having to cut any of the factory plastic air scoop bits
Shot at 2011-07-09
Shot at 2011-07-09
Shot at 2011-07-09
nice hehehe, is it running yet ? did you bought new loom or modified the aristo one ? did you changed the fan and the waterr pump ? :-ss ...
51%
, 49%
...don't push it !!!
- twojayzeejza
na still not running yet, still need to modify the loom to suit. It looks as though it had a supra water pump put on due to the length of the studs but im running electric twin 10in fans any way. Not far off now intercooler and piping all sorted, got the replacement breather hoses etc from NST cheers nic, now all left to do is put a couple more bellhousing bolts in, mount starter motor, mount slave cylinder, drill and tap fitting into intake manifold for brake booster, sort out front half of exhaust and modify the loom.C1up3r0 wrote:nice hehehe, is it running yet ? did you bought new loom or modified the aristo one ? did you changed the fan and the waterr pump ? :-ss ...
I'm pretty sure it's recommended not to change to electric fans on the 2JZGTE as the standard one is better (correct me if I'm wrong)?
1995 Toyota Supra - Twin-turbo - 6-speed - Aerotop
No ABS. No Traction Control.
