jzx90 manual clutch pedal alternatives???
Re: jzx90 manual clutch pedal alternatives???
I used a EE100 bracket and pedal. It bolts to the firewall sweet but to stop it flexing it needs a small bracket about 20x30mm to go at the top where the original footbrake mounts. Had to cut and weld the pedal to sit further to the right. Operates 100% but the layout of the pedal doesn't look factory.
