anyone tried this at all? seems no one has.
im assuming altezza ones are longer, so might get a camber gain and more steering.
can anyone measure how long an altezza lca is from center hole to center hole?
cheers.
sexy10 altezza front lca's in jzx90? (not the castor rods)
Re: sexy10 altezza front lca's in jzx90? (not the castor rod
I thought the front suspension gear on the front of the sxe10 was the same are the 90/100 as well, i definitely know its the same as the 110. I know the rear set ups between the 90 and sxe10 are completely different.
well... i know the caster rod bolt sizes are different. sexy 10 altezzas being bigger to jzx90
the differences between the length, however... ?
