HKS Camshafts and Adjustable Camgear All to suit 1JZGTE VVTI
Genuine Toyota parts, Performance Parts, Tires, Servicing etc..
Moderators: PowderJZX, xnickx, VR25
xnickx
Post by xnickx »
If you are after any other parts which is not listed here or any enquiries about these camshafts or gears, please SEE HERE and get in touch with me rather than posting here.
These are all VVTI Compatible.
Intake only lists a 264.
Exhaust you have a choice of 256 / 264 or 272.
If the ones you require are not in stock, they will get sent from HKS to me (no chance of drop shipping to Australia sorry) and that'll only take about 2 weeks.
HKS Intake Camshaft 264
Part number - 22002-AT003
Opening - 264 Degrees
Lift - 8.6mm
RRP - $1058.95+GST
JZX-NZ Members - $875.00+GST
HKS Exhaust Camshaft 256
Part number - 2202-RT076
Opening - 256 Degrees
Lift - 8.7mm
RRP - $875.30+GST
JZX-NZ Members - $725.00+GST
HKS Exhaust Camshaft 264
Part number - 2202-RT078
Lift - 9.0mm
RRP - $875.30+GST
HKS Exhaust Camshaft 272
Part number - 2202-RT080
Opening - 272 Degrees
Lift - 9.0mm
RRP - $875.30+GST
HKS Adjustable Timing Gear (for use on Exhaust Cam only)
Part number - 22004-AT003
Type - Aluminium Slide
RRP - $310.60+GST
JZX-NZ Members - $245.00+GST
Images:
Link for more reading:
http://www.hks-power.co.jp/products/eng ... shaft.html
*Please note, prices shown do not include GST! (aka +GST)
To order any of these, please see HERE
All these are are 100% Genuine HKS from Japan!
Shipping: (for 1 x intake cam, 1 x exhaust cam and 1 x camgear)
Current stock - 12/12/2011
Intake 264 - 1 in stock / 0 on order
Exhaust 256 - 0 in stock / 0 on order
Exhaust 264 - 1 in stock / 0 on order
Exhaust 272 - 0 in stock / 0 on order
Adj Camgear - 2 in stock / 0 on order
If you need something that's not in stock, it'll take approx 12 working days to land in from Japan.
