jzx body parts bolt on to others of the same shape?
No body likes an ugly duckling...
gtivvl
Post by gtivvl »
for example the nissan 180sx and s13 silvia front ends are interchangeable....are x chassis the same? can I bolt a x90 chaser front end to an x90 cresta?
Jonno2002
Re: jzx body parts bolt on to others of the same shape?
Post by Jonno2002 »
you can on x8 so i dont see why u couldnt on x9 and x10 but yea cant say for sure, x8 is a big yes
gtivvl
Post by gtivvl »
cheers for the reply....reason I ask is i have and x90 cresta and factory bits are so hard to find...but mark II and chaser bits are relatively common
Jonno2002
Post by Jonno2002 »
youve got it easy, try finding parts for x8's which arent ugly cressida shape.
id say go for the mark2 front if you can as its hands down the best shape
boosta92
Post by boosta92 »
x10 isnt 100% the same but bolts up you have to mate the guards together just did mine today
viewtopic.php?f=32&t=1195
ROBAPHENT
Post by ROBAPHENT »
JZX81 Chaser front end and then remove head light lens then remove the inside of the lens and put outside of lens back on for clear lens. Makes car look 100% better then any other x8
still trying to make my own clear lens
CISCOKIDS
The Gentlemen's Club
Midnight Rocker
