Wide body JZX90
Posted: Fri Dec 09, 2011 8:43 pm
by V12
Hi guys, im pretty much in VIP Style but the JZX90 only takes weak Offsets under the fender.
I found +20mm Origin Frontfenders but nothhing for the rear end.
Has anyone a widebodykit or knows a trustworthy shop (wich homepage aint in japanneese ;-)where i can at least buy the origins?
Re: Wide body JZX90
Posted: Sun Dec 11, 2011 12:12 am
For a Mark II? What kinda width/offset do you want to run at the back? I run 18x10 +24 with 235/40's and still have a bit of room to play with. I reckon you could run 9.5" wide with 225/40's and get away with a 0 offset on the standard guards if you pump them out a bit. You won't find aftermarket rear guards for 90 Mark II's because they're pillarless - alot of strength is in the rear fenders.
For the Origin's, get in touch with Ewan from,
www.hayatonka.com, he will organise the purchase/shipping, all you have to do is pay. He's a good guy, and owns a JZX90 himself too. Also try jessestreeter.com, same deal just tell him what you want and he'll find/buy/ship it to ya.
Re: Wide body JZX90
Posted: Mon Dec 12, 2011 8:33 pm
by V12
Thank you for the advise.
im currently running 10x19et18 with a 245 and i have to flare the arches a little bit.
But i want to run my Work emitz 12x18et0 with a 295.
These wheels would look dope on the Mark 2 but need a +50mm flare to fit
