stop light
Posted: Fri Oct 14, 2011 10:23 am
by Ventourer
hi chaps, so im wondering if i pull off my factory rear wing, i will need to fit a high stop light.
any ideas how? LED strip in back window, low, high?
cheers
Re: stop light
Posted: Fri Oct 14, 2011 12:46 pm
you can buy a generic high stop light from repco.
trace the high stop wiring back and run it through to the back window instead of into the bootlid
Re: stop light
Posted: Fri Nov 09, 2012 4:23 am
by Dwight
Hi all i had same problem them i was purchased the generic high stop light i have also my suggestion is that you can buy a generic high stop light from repco.
Re: stop light
Posted: Mon Nov 12, 2012 12:15 pm
by lofreq
Dwight wrote:Hi all i had same problem them i was purchased the generic high stop light i have also my suggestion is that you can buy a generic high stop light from repco.
Dwight what are the differences between a repcohigh stop light and a LED light?
Re: stop light
Posted: Mon Nov 12, 2012 9:20 pm
the difference is in the blinker fluid you purchase from repco............come on nige jeeee wizz
