stop light
No body likes an ugly duckling...
Ventourer
stop light
Post by Ventourer »
hi chaps, so im wondering if i pull off my factory rear wing, i will need to fit a high stop light.
any ideas how? LED strip in back window, low, high?
cheers
Re: stop light
you can buy a generic high stop light from repco.
trace the high stop wiring back and run it through to the back window instead of into the bootlid :)
Dwight
Re: stop light
Post by Dwight »
Hi all i had same problem them i was purchased the generic high stop light i have also my suggestion is that you can buy a generic high stop light from repco.
lofreq
Re: stop light
Post by lofreq »
Dwight wrote:Hi all i had same problem them i was purchased the generic high stop light i have also my suggestion is that you can buy a generic high stop light from repco.
Dwight what are the differences between a repcohigh stop light and a LED light?
Re: stop light
the difference is in the blinker fluid you purchase from repco............come on nige jeeee wizz :lol:
