Pasted from New to JDM with a freshly imported Tourer V 1993 in members cars.
For a great free service, Tyre Works in under 2 minutes gives you the toe and camber on a printout. The guy was rapt that I knew all the model details considering it was an import and the flash new alignment machine had the standard specs for my year/ make/ model. It lists them out as a range value, obviously with the middle being the factory recommended.
All of mine were off the range and are approximates..... bit like me really.
Factory\ Mine
Front Toe 0.5mm\ -0.25mm
Front camber -0.25deg\ -0.9 deg
Rear toe 1.0mm\ 1.5mm
Rear camber -0.67deg\ -1.4 deg
