hid headlight wiring
No body likes an ugly duckling...
boosta92
Post by boosta92 »
Ok Im doing my chaser font conversion, I have chaser tourer v front, now the park light and center lamp have the same plugs but now i have the issue of the standard halogen 3 wire high and low beam plug to go into the 2 wire hid ballast plugs.
Should i be running the hids off a relay with separate power, will the hids draw to much current through the standard halogen wiring?
What am i to do here? any suggestions
Cheers James
Vasco
Re: hid headlight wiring
Post by Vasco »
boosta92 wrote:Ok Im doing my chaser font HID conversion, I have chaser tourer v front, now the park light and center lamp have the same plugs but now i have the issue of the standard halogen 3 wire high and low beam plug to go into the 2 wire hid ballast plugs.
Cheers James
Connect Blue wire to the high beam, red wire to the low beam and black to the ground.
