headlights
No body likes an ugly duckling...
PowderJZX
headlights
Post by PowderJZX »
do you guyz know how i can clean my headlight to its original condition? left headlight is faded.
lofreq
Re: headlights
Post by lofreq »
saw this headlight polishing kit in repco which removes all yellowed and faded wear on lenses and restores it to crystal clear state. probably has jus the right amount of abrasive to get it done. id say try that
ryanfels
Re: headlights
Post by ryanfels »
My panel beater mate just does it with cut and polish
Alex
Re: headlights
Post by Alex »
yeah you can use the proper headlight cleaning stuff
or just cut and polish works all good
Max Power
Re: headlights
Post by Max Power »
I have always used "Meguiars PlastX" on faded/dirty headlights.
Its a polish designed for plastic parts.
gxfeints
Re: headlights
Post by gxfeints »
I recently done the headlights on my ae101 levin, wet sanded with 1000 grit wet and dry paper then 1500 and finally 2000. After that gave em a good rub with autosol.
Came up really well but maybe the sanding was unnessesary. :oops:
My Mark II has a really yellow drivers headlight i might try polishing with the the autosol only, save the sanding.
Fraud
Re: headlights
Post by Fraud »
Mine are yellowed inside too, anyone split lenses off lights before? Apparently it is straight forward, I think you just have to go slow etc...
Any help / advice appreciated!
SimonMkII
Re: headlights
Post by SimonMkII »
Fraud wrote:Mine are yellowed inside too, anyone split lenses off lights before? Apparently it is straight forward, I think you just have to go slow etc...
If you're going to split them you need to put them in the oven! There's instructions on the aussie jzx forums somehwere. Something like 5 minutes at 150 degrees will melt the sealant that holds the lens to the body of the headlight.
Looonie
Re: headlights
Post by Looonie »
Cut and polish with a rotary buffer works best on the outside. Do this step first, if you find its still yellow then you will probably need to bake them and polish up the inside.
Inside is a bit harder due to confines and curves, can be done using toothpaste, brasso, plastic polish or normal cut and polish. Soft cloth or attachment on a dremel or drill if you have it. Need to open the headlight to get to it, can be either baked in the oven or use a heat gun around the join to soften the mastic and pry the two pieces apart. Just make sure to keep the mastic evenly coated and soften it again when you press back together to properly seal or you end up with condensation in your headlights.
SimonMkII
Re: headlights
Post by SimonMkII »
So who wants to lend me a rotary buffer?
